Flywheel Damper
Boy am I bummed............Need to find a flywheel damper for my 92 tipronic. Any help would be appreciated.
Ross
866-426-4148
Ross Carley
Newtown, CT 06470
1992 968 Tip. Cab. (Slate Gray) purchased 4/2008
1965 356 SC Coupe (Iight Ivory) purchased 10/1976 $2500 ( now undergoing complete restro help me chose a color)
1970 914-6 (Irish Green) purchased new March 1970 $6800 sold it 10 months later a real POS
1964 356 SC Coupe (Irish Green) purchased 1969 $2700 blew it up on the Tapanzee Bridge 3AM at 90+
1966 Austin Healy 3000 (BRG) purchased 1968 They came as a set $1200 for both
1966 Austin Healy 3000 (Guard Red) purchased 1968 " " " " " " "
1961 Austin Healy 3000 ( Silver Blue) purchased 1967 $400
1953 Le Francis (Le Mans White) 3 speed twin overhead cams purchsed 1966 $600
sunset? i wouldn't put in a used one, that's for sure
[quote name='flash' post='61056' date='Oct 2 2008, 05:31 PM']sunset? i wouldn't put in a used one, that's for sure[/quote]
Where would I find a new one??????????
Ross Carley
Newtown, CT 06470
sunset
Sunset Imports
800.346.0182
You could also try Pargon or Pelican.
Ask for Jeff in Parts at the aforementioned Sunset Porsche dealership.
None are available from PCNA or from Germany as of 10/03/08. I have a lead on a new one though.
Yikes!!!!
[quote name='RS Barn' post='61118' date='Oct 3 2008, 08:28 PM']None are available from PCNA or from Germany as of 10/03/08. I have a lead on a new one though.
Yikes!!!![/quote]
That sounds bad...
Ouch, yeah Pete, what about the next time one of ours goes bad. I wrote in the other post that mine was replaced in 2005. Guess it is time to think about alternatives. Wish I had kept my Lincoln Logs and Erector Set <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" /> . No seriously, anybody have ideas on this part, is there one from 911s with Tips that could serve the purpose, with modifications perhaps?
Roland
Roland
well I found two.............$1056.00 is the best price I got. When I spoke to Sunset the parts guy Jeff? said he knew of one in Texas and that one was not for sale. I called anyway cause come to find out that was the dealership where my Cab was bought. Weird huh? The owner of the dealership is saving it for his wifes car. I did try Pelican they have always been helpful with parts for my other car. He said he had one for about $1200.00 bucks. If anyone else needs one call me .866-426-4148 I've done the leg work for you. I was thinking of milling some of these guys from an aluminum billit............any interest?
Thanks again for you support. I was a bit frazzled trying to figure a way out of this. I have fears that I've bought a money pit.
TGFTI
(Thank God For The Internet)
Ross
Ross Carley
Newtown, CT 06470
Is this a tip thing only or can we expect to see this in manuals as well? we all have flywheels right?
tip thing
Well it looks like even the 6 speed has its issues. Like ring and pinion gear noise. Lose Lose I guess.
"Ya know Jane It's always something." Needless to say what the wife says
Ross
Ross Carley
Newtown, CT 06470
I just had mine done in the summer.
I'm told that the rubber deteriorates from ozone, etc., and will last longer if the car is driven more - just as tires deteriorate if they aren't driven.
Pics are attached (I hope...)
Another pic.
1992 968 Cab Tip, Guards Red on black.
1998 Volvo V70R AWD
2000 BMW R1100s
2003 KTM 450 EXC
1983 Bimota KB2 Laser TT
1972 Laverda 750 SF
The clutch in my old 944 looked very similar .
Clutch something like this? This was the clutch in my 944S when I bought it, it just spun and never engaged.
Looks like a little JB Weld on these babies would take care of the problem <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> and we won't have to find new sources.
(OK fine ... I get it ... probably won't hold ... I'll confess, I have been known to use a bit of coat hanger here and there <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> )
Roland
Roland
does that bolt to the regular flywheel?
i would love to see how that goes together
The flywheel can be seen towards the right in the '02 pic. The other is a close-up of the stop that engages the damper plate to allow the car to be driven (not too long) after the damper plate fails.
[quote name='PaulT' post='61294' date='Oct 7 2008, 07:44 PM']The flywheel can be seen towards the right in the '02 pic. The other is a close-up of the stop that engages the damper plate to allow the car to be driven (not too long) after the damper plate fails.[/quote]
1998 Volvo V70R AWD
2000 BMW R1100s
2003 KTM 450 EXC
1972 Laverda 750 SF
[quote name='banditsc' post='61290' date='Oct 7 2008, 07:16 PM']Clutch something like this? This was the clutch in my 944S when I bought it, it just spun and never engaged.[/quote]
Hey thats my disk! <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
No JK.
Exactly what mine looked like.
10-14-2014, 12:25 PM
Last Post by Johannvb
08-04-2010, 05:42 AM
Last Post by TheJoe
09-16-2009, 06:57 PM
