Threads: 18
I've read references to retarding or advancing the timing on the 94/968 range of engines. I'm a bit confused, as from what I have seen from my cars is that the distributer is mechanically driven off the one cam which is driven off the crank. Basically, its all mechanical. The ECU does not have direct control of the ignition spark other than the influence via variocam that 'shifts' the cam and thus effects the distributor/spark. This 'control' is not in the hands of the user, its purely ECU driven.
Am I thinking right? And if so, can I assume these guys are talking of third party 'Sparky' systems that do not use the distributor.
18 Jaguar V6 P380
Threads: 18
Ok... so if I have it right, the advance/retard is purely cam/valve related. I always thought it was to do with the moment of spark. Yes?
18 Jaguar V6 P380
(This post was last modified: 05-13-2011, 08:22 AM by
DayDreamer.)
