[quote name='flash' timestamp='1352230889' post='134493']
Check the vacuum reading at the end of the hose that connects to the blow off valve
17.4"inch
Oke , i did something silly but i works .
First i disconnected all the vacuum lines also the ones under the manifold , took the rubber elbows etc off , checked all for leaks and obstructions .
Did not find anything wrong with any of them , put everything back , same noise .
Took the blow off valve off , looked checked operation , and found when it was retracting (opening(vacuum applied) is was not doing it in a square way , so one side opens quicker then the other , same goes for when it closes .
So now the silly part , i put it back the other way around , so the vacuum part is faceing sideways instead of downwards .
And the SC air is not pusing on the valve as before (helping it open )
It is not D1R like that , but it works , and most important the trompet like sound is Gone .
Also it gained power down low , i think because the valve is not opening and closing in a square way it is has trouble closing the last gap resulting in the anoying sound , and i lost some boost down low .
Downside is the design off the valve and the way it should be installed, it might not be opening as fast as it should because it is not supported by the boostpressure when opening .
Will put some miles on it and see what happens .
And wait for the doc Flash to see what he thinks .
Did about 20km , yes yes yes , perfect , no noise , better power down low , went up in the rev's just before the limiter comes in , no issue's no funny trompet noises , down low perfect and the boost valve seems to work fine this way .
