Well well i have the car running again , had to put a lot of time in to get it right again .
Drove the car to france for a vacation , it did preform well , had the belt and 1 ideler pully changed because there was no evidence of grease in it and it went bad , as a precaution changed the belt as well , it turned out to be a problem finding one in europe , finally i did and Flash send met 2 extra belts and a set of idler pully's so i have them for spair in case needed in the future .
Now the rest of the problems , drove the car to work 30min drive , all fine no problems , when i finshed work 4 in the morning i fired the car up and it started right up for maybe 5 sec and it died , that was it , after trying i could keep it running , keeping it above 2000rpm . and with a lot of sputter and gas smell from way to much fuel being sprayed in there managed to get it home .
First i suspected the icv , changed it with a new one lot's off $$ , and no change exept it would stay idle now but as soon as i thouched the throttle it would stall .
Then i went around to check all the sensor's first did not find anything bad except the hall sender plug came apart so decided tho get new HAll <acronym title='throttle position sensor'>TPS</acronym> and CPS .
So the problem could not be in one of those , also measured the value's at the dme computer to make so the problem could not be in the wires somwhere .
But no change in the behavior , then i changed the dme computer , i had one around because i had bought one to have the right one and tested for the SC buildt .
And it was running again , but it did not make me happy , there was a lot of hesitation especially in the higher revs , changed the <acronym title='mass air flow'>MAF</acronym> for a good working used one and that finally did the trick , i have no clue what happend that the <acronym title='mass air flow'>MAF</acronym> and dme coputer went bad both at the same time .
It did cost me about 1000$ but now it runs beter then ever .
Also i fiddeld around with the cam timing a bit , just to see what it does and this might be some thing other sc driver migth benefit from .
I marked the cam gear for reference and so i could put it back to where it was before .
First i advanced the cam's as far as they would go , that does not work , it actually started to make inlet noise(backfire kind of noise) and started hesitating when accelerating under 2500rpm , above that it ran fine .
It also seemed to run hotter when in slow traffic .
Then i started to retard the cam timing bit by bit , and it became better and better , i finally adjusted it a tiny bit late then where it was before and now the hesitation bit is completly gone in the low rev's , so if you have any problems with HESITATION under 2500 rpm you might want to check your cam timing .
I will drive it for i while because it runs really well now , and check the timing again with the dail gauge when i have time and feel like it .
I was pretty sure i had the timing nailed before but it might be an issue with the SC to have it spot on , wich would be the best no matter what offcourse .
The only question that remains is , am i spot on now ?
Vacuum is good , i did check again it wil take way over 10 min for the pressure to drop of completly .
