Does diagnostic port have a fuse associated with it
Having problems getting power to Bergvill device on 1994, 968.
what's a bergvill device?
not sure the diagnostic port sends power though, regardless.  i believe the hammer is self powered, and the durametric uses the laptop power, so it wouldn't need to send power.  frankly, i never checked.
Bergvill device is T-OBD reset tool sold by "Tore Bergvill " in Norway, device passes test with 9 volt battery but will not
Show response thru 19 pin connector, have used two different connectors.
OBD2 devices do not work on this car.  to my knowledge, only the durametric and the bosch hammer can read this car.  it is OBD1 and not OBD2.  the language is very different.
Flash,
See -
April 5th 2013 post.
???  what post? where?  huh?
You can find many OBD2 to OBD1 ( and vice versa ) adapters-converters on eBay for about $ 20 or so.. The one I bought "adapted" very well right into the garbage can .. I think flash is right, the instruments must have completely different language . Or maybe I just had a faulty adapter right out of the box, but I was not willing to try another one ..
See Joe's ,Birmingham Al, Air bag reset post April 5, 2013 . I think the 19 pin connector I purchased for another source is wired
Incorrectly.
This place,
http://www.bergvillfx.com/index.php/products.html?p=3
I have the diagrams for the adapter but you need his obd11 to 19 pin for it to work
i still don't think it will work.  all attempts to date to use an OBD2 device on our OBD1 ECU have failed.
It's not OBDII it's an interface he's built that speaks the right system just has an 14 pin standard OBDII plug
He did it like that so you have to buy his converter lead to make it work, one guy over here has one and it works
Durametric is much better but a bigger investment
what software does it use?  what capabilities does it have?  the only thing i've heard of so far, other than what i mentioned, was a gadget that could reset the idiot light, but it didn't do anything else.  it would be nice if there were something else out there.
http://www.968forums.com/topic/3684-rese...ng-light/#
Read this topic. Than you have scheme for connecting the wires. It is very simple
You don't need his 19 pins connector. But the connector is handy..
He uses the same software from Doug..
Ritchie.
He has copied the interface from Andy.
Received my Bergvill 19 pin connector works great to reset the air bag light, thank you Tore, but cannot get the Motronic info to connect, anyone else have a the same problem/ possible solution.
The motronic is possible by changing the adress in the software and the other thing is that the motronic can be read out with the blinking method.
09-13-2025, 07:36 PM
Last Post by Roboman
05-30-2020, 08:23 AM
Last Post by dlearl476
08-29-2016, 11:01 PM
Last Post by hot968
09-15-2013, 08:57 PM
05-17-2013, 12:52 PM
