DME-relay
Fitted new air filter today and wanted to take it for a test drive. I turn the key and all is normal (all lights ok and engine cranks) but it doesn't start. I make two 10 second attempts. It acts as if I had disconnected the plug wires. I pop the hood to check the wire from the coil to the cap sicne I had just messed around in that area. All is ok so I close the hood and I activate and deactivate the alarm. New try but same result - crap! Now it is dinner time so the car sits for like one hour before I get to start working on it. So, back outside I decide to give it another try before I start troubleshooting. And it starts instantly!?! I try again and again and it works perfectly. Just a temporary fluke or could it be the DME-relay going bad? Or something else? It's running now but this problem might come back at a bad time so I'd like to get it fixed.
Yes, the car will crank with a bad DME relay. The relay sends power to the ECU.
Pick up another relay for peace of mind.
before I replaced mine, that was one of the sypmtoms.. ( among others - it's amazing how may "scary" , different symptoms that single $ 20 unit can create.. )
<!--quoteo(post=76567:date=Aug 1 2009, 12:06 AM:name=ds968)-->QUOTE (ds968 @ Aug 1 2009, 12:06 AM) <{POST_SNAPBACK}><!--quotec-->+1
before I replaced mine, that was one of the sypmtoms.. ( among others - it's amazing how may "scary" , different symptoms that single $ 20 unit can create.. )<!--QuoteEnd--><!--QuoteEEnd-->
I have now made the "emergency cable" that connects the 30, 87, and 87b connectors so that I can replace/bypass the DME relay with it the next time this happens. And I'll buy a new relay - should I go for an original part (the newish one with a 993... p/n) or simply whatever new one that works?
I'd rather not simply replace the relay assuming that the relay is where the problem is. I would like to verify it first by getting this problem again and then fixing it by replacing the relay with a cable or a new relay.
Get the 993 part number one.... I don't even know if you can get the original one anymore (probably a 928 or 944 PN).
I replaced mine with the 993 part number and keep the original as a spare- it worked when it was installed so should still be good.
Ok, thanks!
Last Post by RS Barn
06-17-2018, 06:55 PM
Last Post by rl968
02-17-2011, 10:24 PM
Last Post by Kim
06-21-2010, 01:00 PM
Last Post by BruceWard
07-13-2005, 11:23 PM
