[quote name='Greimann' date='Mar 18 2006, 08:41 PM']Not a dumb question at all. You are right, the documentation is not apparent in any manual.
Starting at the top terminal - 3, 1, 2, 4
[right][post="17549"]<{POST_SNAPBACK}>[/post][/right][/quote]
Awesome. Started the car and at first it died; Almost had a a heartattack. Forgot to tighten the fuel lines when i changed the spark plug seals. Fixed that and it fired right up. No belt whine after 3-4 seconds. For some reason, the noise when starting doesn't sound like a whine, it's more like the car is struggling to start up. Oil is also pouring onto my exaust headers.... luckily i have another valve cover gasket. The bolts aren't tightened very much on the cover? 7 ft*lbs. Thankyou all for your help, this would not have been a successful project without your help.
... it is me, or every time i look at the balance belt i'm afraid it's going to skip a tooth. Did the 110* turn at center of longest run. i think it's ok though.
