Spring is coming, and with it are those great spring drives. Don't let your day be ruined by a call for a tow truck.
The OEM High Pressure Clutch Line is prone to failure from age. They are only rated for 5 years. They fail from the inside and you can't see it degrading. The only sign you may see is the dreaded "EGG" where the rubber meets the hardline, but it doesn't always happen. What does happen is the sudden "bang" and the pedal goes to the floor and stays there.
The Design 1 Racing Stainless Steel braided Teflon lined Clutch Line eliminates this from happening, and firms up the pedal a bit at the same time.
Do yourself a favor. If you haven't already installed one of these, and you're still on the original hose, get yourself the piece of mind and do it before you have to call a tow truck.
Now until Easter, the Clutch Line is on sale for 20% off!!!
http://shop.design1r...h-Line-SSC1.htm
www.968forums.com
