Threads: 77
Threads: 63
I just did the CV boot replace and also cleaned and repacked the inner driver's side cv joint. Not a fun job - greasy, messy- i dropped the exhaust and pulled the entire axle so I could get the thing on the bench. Ball bearings were good - races good, except for finding some metal shavings in the grease. Not good. Here is what I found:
That's the innermost race that slides over the splines on the end of the axle. Do you see the gouge out of the top right? That's where the metal came from. Not having a spare cv joint on hand, I cleaned everything up, repacked it with grease, installed the new boot, and threw everything back together.
How long do I have? Taking bets....
SOLD! 1992 - 968
(This post was last modified: 01-03-2011, 05:18 AM by
Scott Collins.)
Threads: 2
Just replaced the inside driver's side boot on my 6 speed. A few things I found out:
1. The direct replacement part is $30 but the
944 one goes for $10 - this adds up if want to do all four.
2. The cheaper one fits fine, you just have to reuse your original fastening clip
3. If you're really feeling thrifty you can buy just the rubber boot for $5 - this could make you a great spare for cheap!
It's the same one used on the Boxster and several 911s - here's a link
http://www.paragon-products.com/CV_Joint...293.02.htm
You have to use your original metal frame (assuming you're replacing an OE boot and not the 944 one)
You can buy a version which comes with grease and the correct fasteners - this goes for $13
http://www.paragon-products.com/product_...924.02.htm
These boots uses a tougher grade of rubber compared to the $10 944 one
4. The biggest thing I learned from this is that the muffler heat will cook your CV grease. I'm going to do the right side next and see if that's as bad, I'm guessing not.
I'd recommend buying the complete $13 Boxtser type one because it comes with grease and new fasteners.
1994 968 - currently under construction
1988 944NA - owned for five years
Threads: 2
Thanks, yes that’s valve timing setup. I think you can do fine with just a dial gauge to indicate <acronym title='top dead center'>TDC</acronym>, then reset to your cam gear the same way it came off. There is a ton of info on the subject, but it doesn’t need to be that difficult. You can use zip ties to help you squeeze the unit place before assembly and be very carful to evenly torque down the cams. Take your time make sure your cam carriers are oriented correctly.
In addition to the great write ups on this site, I also found the photos on this piece helpful http://docwilenracing.wordpress.com/2009...intenance/
Threads: 2
