<!--quoteo(post=70561:date=Apr 19 2009, 06:05 AM:name=jrallen01)-->QUOTE (jrallen01 @ Apr 19 2009, 06:05 AM)
<{POST_SNAPBACK}><!--quotec-->I have a '94 968 Cab. Last night, the cooling fans did not turn off and my son noticed them running an hour later.
I pulled the fan relay and of course they stopped. Does anyone have a quick idea on isolating the fault between the sensor and the relay?,
Thanks<!--QuoteEnd--><!--QuoteEEnd-->
I pulled the case off of the relay and could see the contacts move back and forth. Points look good. I replaced the case and finally located the Fan Sensor on the driver's side of the radiator right below the upper hose. It's a bear to get at it and disconnect the wire. The fans no longer run.
I am assuming a high probability of $11 thermal fan sensor failure.... and not the $168 relay.
Thanks for the reply.
