considering a los angeles area dyno day
having done a lot of this already, i have been reluctant to put one of these together because they are really so much work to get any results that mean anything - it is so easy to screw up and get bad numbers (i see it all the time at those "quickie dyno days") - the price is so inviting that people jump in and expect to get real results, but what they get is almost always garbage, because they don't take the time to measure everything - failing to do that can throw the numbers off by as much as 20 hp in either direction on this car (heck, moving the intake temp sensor 8 inches tossed it off by 10) - all you get on those kinds of dyno days is "it did this on this day under these known and unknown conditions", but you don't get anything that is relevant
but after all the mods and such that have been done, it seems there are those who would like to know what the results have been - sure, i have already tested a lot of this stuff under very controlled conditions, shown dyno charts and such, as have other people with the same results, so there is no reason to test that again, but it seems to be a popular idea to test your own car to see where you are - that's cool - it would be fun
so that the tests would be valid, of course we would measure all the atmospheric conditions - if we want to know flywheel numbers, we would also measure drivetrain loss and not merely plug in a number - every car is different - even things like tire wear affects the drivetrain loss (less mass=less loss) - either way, we would also control the most important factors like engine temp, intake temp, gearbox temp, strap tension, tire pressure, etc - we should also check the compression of each engine to give a relative result (lower compression means lower power) - a leakdown would be better, but i think i will have to do that another day (ooh - another gathering and more beer?) - this would be the only way to give any results that would mean anything
anyway, it means probably close to an hour and a half per car for 3 good pulls - we could probably get 6-8 cars done in a day - this does not include the time to do a compression check, and warm up the gearbox - skipping any steps or going any faster and the results will be meaningless and pretty much nothing but a circle jerk (still usually a fun day, but worthless data)
i can scout around for a dyno that can be relied on to be accurate, well maintained, and recently calibrated (not just cheap or available), and i imagine it would probably be about $150 per car - i might be able to work out a better deal - i can find out
anybody interested?
I see this thread up here and keep thinking to myself "Man, this would be such a great trip!" Basically an excuse to take some time off work and go down south to get my car checked out by the expert(s), and meet the people on this forum. For me there is enough to justify taking that week off and booking it down there to join in the fun <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> (Road trip down the west coast? Woot! Meeting more 968 people? Yay! FINALLY seeing California? Great!)
Biggest issue, as always, is timing and finances. I don't plan on doing the front end and vario cam until September, and that month will be packed full of weddings, milestones, etc. Those engine repairs need to be done and over with before I feel confident enough to take a long road trip.
Flash, did you have any particular date or time in mind for this? Or simply whenever there is enough people to justify it? At this point I would be hesitant to make any concrete plans for myself, but depending on when / if this happens, I may end up doing the trip. Naturally the further in the future it is, and the further north it is the better <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
-Ren
as i continue to read more threads, which clearly show how little many people know about dynos and how they work, and more importantly how you CAN'T compare uncontrolled runs from one to the next, or draw any conclusions based on somebody else's run, i get more and more motivated to put this event together
i see dumb things like general comments about mustang dynos reading low, as if the new ones are anything like the old ones (even i made similar comments before i knew better) - most people don't know what "eddy current" means, or the difference between what an 18" roller and a 24" roller will do - that's ok, but it makes me absolutely nuts, because it is so misleading to so many, when people make ill-informed comments about results - i'd like to straighten a lot of this out
perhaps it's time for a dyno clinic, but before i go on a rant.......
it's time to show how much improvement these things have made - we all know the rs barn chip, combined with the airbox mod dave and i did, make about 20 - we all know already what different chips below that do, and what the box mod does - we have no data on exhausts, and i'd like to get some of that - so far, nobody has published runs with the entire package of all the goodies available, though i have heard rumours of runs with 230 at the wheels (pretty sure we'll confirmation of at least that pretty soon)
there are a couple of mods left to do before i am ready to go again, but i am getting a lot closer - however, mine won't be representative of what most people can do - i would really like to get some other cars with different combinations
as for the date, i'm not sure - yes, it is highly dependent on participation - however, i will be doing some runs on my car regardless of others - it will be before winter (tires need to be dry) - probably october
location will likely be near me, especially if i am the only one doing it - i will be poking around on this in the next few days to find one
there won't be room for a lot of cars, as it just takes too long to set up, get the transaxle heated up, the engine evenly heated etc., and get all the necessary readings to insure accuracy - i'm thinking 6 is probably the max - so, get ahold of me if you want to be in on this
I might be interested in putting the Z on the dyno. I'd like to get it settled first, not sure it is running optimally currently.
Ken
Ps-The 350z board is boring, very low brow.
did not want to start a new thread, but rather, suggesting that Bob changes the name of this one to los angeles area DINING day <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" /> , because I need a reason to drive down for another get together with a few 968 SoCal friends ( I'm thinking Nov/Dec timeframe..? ) <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
well, that part was a given
10-08-2018, 08:22 AM
01-27-2012, 11:54 PM
Last Post by banditsc
08-30-2011, 08:10 PM
Last Post by bva
02-21-2011, 08:06 PM
