05-10-2016, 09:12 PM
With my A/C unit turned on (I just installed a brand new A/C compressor with new belts for a/c and power steering) my car is now running hot. We checked that there is enough coolant in the car, no leaks, etc. But the car runs hot. Last week I went for a drive, when the outside temp was 89 degrees I turned on the A/C. it worked great, never was the interior this cool before, perhaps it needed a charge of A/C coolant before. I parked the car for about one hour and then started to drive home. First the rectangular red light in the middle of the dash came on, then I noticed the temp gauge was all the way to the top and found out there is a led light at the top of the temp gauge, which comes on when the temp is too high. I shut off the A/C to allow the engine to cool which it did slightly and continued to drive home. When I got home I popped the hood. No leaks no A/C coolant sprayed under the hood, all the belts are intact and turning with the engine. The fan blades in the front of the A/C unit were spinning as the engine was running.
Any ideas of why the engine is running hot?
