[quote name='xrad' post='56570' date='Jul 21 2008, 06:08 PM']Does anyone know absolutely if the upper and lower chain tensioner pads are exactly the same?
What do you guys recommend for the best timing chain? (endless links like Iwis? or something heavy duty?)[/quote]
As pointed out elsewhere, the top and bottom pads, on the 968, are identical. On chains, I would recommend going OEM. Get you parts through Sunset Porsche and the price on the chain, if I remember correctly, is about $50. The chain does not have a removable link which is why you must remove the cams to replace the chain.
If you decide to do the job yourself, allow about 12 hours the first time around. Having done the job the first time in about that number of hours, I now believe that I could do it in less than half that again.
The are several minor items when tearing the system down. Like ways to remove the cam bearing cap bolts which strip easily. There is also an alignment gauge you will have to make to orient the rotation of the cams on reassembly. And, lastly, I highly highly recommend that you get the varicam tensioner lock which allow the tensioner to be held compressed while installing the cams. YOu'll also need the pin that allows you to lock the timing belt tensioner in the compressed state for reassembly.
The nice thing about those tools is that they are cheap and are available from Sunset for about $35 for both retainers. I fashioned my own tools since they were back ordered at Sunset, but have since gotten them from Sunset.
Also, there are a number of excellent DIY posts both on this web site as well as on the Rennlist website.
Let me know how it goes.
Ernie
