Threads: 14
My 92 coupe has the Blaupunkt Ventura CD83 stereo/cd player and the faceplate(LCD display) has become next to impossible to read.If I take my finger and move it around on the screen it will improve the visibility momentarily but will eventually revert back to the muddled look.Any tricks(removable faceplate) that might clear up the screen.Stereo/cd player still works great(I just don't know what radio station or track on cd I am listening to.
92 Black 968 Coupe
2001 Silver Audi TT Quattro Coupe
97 LandRover Discovery SE7 "off road beast"
Past 944s-83,84,86 Turbo,88S
Threads: 3
[quote name='mick968' date='Oct 24 2006, 10:48 AM']My 92 coupe has the Blaupunkt Ventura CD83 stereo/cd player and the faceplate(LCD display) has become next to impossible to read.If I take my finger and move it around on the screen it will improve the visibility momentarily but will eventually revert back to the muddled look.Any tricks(removable faceplate) that might clear up the screen.Stereo/cd player still works great(I just don't know what radio station or track on cd I am listening to.
[right][post="27192"]<{POST_SNAPBACK}>[/post][/right][/quote]
Mick,
Sounds like your back light on your display is out. Correct? If that is the case and pushing on the faceplate fixes the issue I would begin by cleaning the contacts on the faceplate with alchohol and a Q-Tip. Do not use an excessive amount and use minimal pressure. If it still does not work I would gently pull the pins up on the unit a very slight amount. Usually these are contact problems and are easily remedied. Please be careful and take your time.
Mike K.
1993 968 Midnight Blue Coupe, 1994 BMW 325ic Green Convertible (wife's), 2002 BMW R1150RT Blue
Threads: 14
Thanks for the tip.Actually,I just did all of that(probably needed to be done anyway) but I think it is actually the display.It lights up,its just garbled looking.I don't know,I guess I will just push buttons until I get what I am looking for(not worth buying new until it quits working).
92 Black 968 Coupe
Threads: 31
Threads: 14
Amazing.Where there's a will there's Ebay!Thanks,for 25 bucks I'll take a chance.Thanks for the info.
92 Black 968 Coupe
Threads: 31
Seller does say if it doesn't work they'll refund so good luck.
