Threads: 31
Do not force it, that could get expensive. I would probably change to manual mode, but wait for more responses before doing so
Threads: 25
As Mark said DON"T FORCE IT, you could break the bows or worse. I dont have a cab so my help is limited but I do know the owners manaul tells you how to enter manual mode.
Rick
Threads: 69
Yes, correct...use the lug wrench (or equivalent) to loosen the two bolts. I think I read somewhere that there is a recommended number of turns to make sure the cable assemblies are fully disengaged, but I may be mistaken about that. IIRC, I backed mine out 3 turns on each side.
The problem when going back would be the inverse of not loosening enough, ie, not getting one side tight and having the motors be pulling at uneven tension from one side to the other. Biggest challenge with the motorized top is broken bows and/or motors not being in sync with each other, which usually causes the broken bow! Never had it happen, but after reading about it, I decided to go manual as well and love it that way...very similar to my Miata. When I first got my 968, I thought "how cool, a power top" but I found it too slow and a pain trying to guide it down so everything would fold up nicely. In manual mode, you can guide it as it goes down and I think it's actually faster.
(This post was last modified: 04-13-2008, 12:03 AM by
Darryl.)
Threads: 24
A bit OT....but when you set the top to manual mode there are some pro`s (point taken)but what about the con`s???
If you ever have to switch back to electronic operation it seems to me you are taking some risks as well (as mentioned in the posts above) or are you just leaving it in the manual mode, for example, if you are selling the car? Or do you take your chances and hope that the motors are in the correct positions?? To me it would be a real bummer if you break one of the bows when you are trying to sell the car....
1992 Amazon green convertible. Cargraphic cat. back exhaust, RS Barn/ Design 1 Racing lower & upper strut brace, RS Barn stage 1 Chip, Airbox modification, M030 Swaybars.
Threads: 24
Hi,
Today I bought another service manual regarding the cabriolet tops on our cars, it contains 60 pages and even the electrical diagrams. I think it was isued fot the 944 S2, but the top & operation are the same (at least I think). Once I get it I will make a scan and put it in the DIY section.
Regards,
Rutger
Threads: 69
Rutger,
Sorry to be the messenger, but I think that manual is here in PDF format...check the DIY section under Misc.
If you obtained something different, my opologies in advance and yes, by all means thanks for sharing.
Threads: 24
Darryl,
The one on the forum is about "sealing" the car. The manual I just bought is different, I checked the numbers...( it also has more pages) It should arrive within 3 days.
Regards,
Rutger
Threads: 24
Hi,
Got the manual in today.....it sure is different then the "sealing" one.....only thing left is to scan the 60 pages.... <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" />
