Black trim
Have a white 94' and the black rubber trim between the left rear sheet metal and plactic bumper is drying out and shortening and causing it to come out of it's groove. The strip appears to wrap around at it's ends and is tacked down with a small screw. I'd like to replace it. Is it as easy as it looks to replace/are there any tricks I should know. Wonder if I could remove the screw on one end to get some lenght and then push the strip back into it's groove. Any other thoughts out there?
if you are talking about the rubber bead, yes it is very easy - do an advanced search here and you will turn up the procedure
Last Post by hot968
08-18-2015, 09:14 PM
Last Post by Bulti
05-22-2015, 06:19 PM
Last Post by ryker
05-02-2015, 11:27 PM
Last Post by BeBe
12-15-2011, 08:00 PM
Last Post by rl968
05-11-2010, 08:07 PM
