Threads: 5
The official interval is 8 years / 60k. If the timing belt breaks you will have down time and greater expense.
Considering the reliability you expect from your 968 I would change it sometime in the next 10K miles and change the variocam chains and pads at the same time. The chain and pads may be ok for now but there is a cost savings to changing them at the same time as the belts.
Threads: 137
my shop says every 30k replace the timing and balance belts...and then re-tension every 10k between changes...
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 5
Jim,
The theory for changing sprockets at the same time as chains is that the originals will have worn to a matching pattern and that a new chain will increase the wear on the sprockets. Personally I understand the logic but have not seen any evidence to support the theory. I plan to change the chains and pads on my 968 over the winter at 63K miles without changing the cam sprockets. The new chain is less prone to stretching and I believe should cause less wear once it is broken in.
If you did want to have your cams resprocketed you are looking at $600 to $700s and at least a week with them out of the car.
As for the head and valves, once you have the cams off you are close to having the head off. You need to take additional steps of removing the exhaust header and intake manifold, then remove the head. The head will require a new head gasket ($200) when reinstalled. Then you would want to have the head and valves cleaned up. I estimate the head cleanup could be done for as little as $400 by a Porsche trained professional or as much as $1200 by someone like Jon Milledge. Sending the head out is likely to mean 1 - 2 weeks of downtime for your 968.
Have you had your injectors serviced? They will need to come out on the way to the variocam and with overnight shipping both ways can be serviced in as little as three days. Many have reported positive results from injector servicing by
http://www.injector.com/ .
(This post was last modified: 11-18-2005, 12:50 PM by
BruceWard.)
Threads: 5
If you were to swap parts instead of sending them out for replacement you should be able to get away with the car at your OPC for one day.
You would need purchase a used head, camshafts and injectors.
I think you could get away with a $2000 temporary expenditure and adding about $2000 to what you would spend for changing the belts and chains.
