Battery Replacement
#61
I bought my last battery at Walmart, just across the highway from my house. I measured the old one and just selected one with the same measurements. They are all on display, no problem.
i'm trying to find a lithium battery with a minumum of 750 CCA and 90 ah
[quote name='flash' timestamp='1408761311' post='161470']
You're handy so make one <img src="/forum/images/smilies/968/smile.png" class="smilie" alt="" />
http://forums.pelicanparts.com/porsche-9...ost7766497
I couldn't find the A123 20 Ah battery sleeves or I'd have cloned this design instead of buying the battery tender...
[quote name='pbc1548' timestamp='1408746985' post='161462']
Replacing the battery in my 92 cab. The old one is a sealed Interstate. I've looked at 2 different replacements and both are vented and come with a small elbow to connect a piece of clear tubing to and a small plug for the other open port. My question is does it matter which side of the battery is vented (pos or neg) and which is plugged. Also, I assume the tubing just sits at the bottom of the tray as there doesn't appear to be a place or a "port" to insert it into. Any advice/input would be appreciated
On my car the tube is on the pos side (closest to the windshield) and is then inserted in the battery tray drain hole.
Jaap
Thanks Jaap. I just took a closer look and there is a depression in the bottom of the tray (windshield side) immediately beside the fixed plate that holds the battery down - must be the drain.
Paul
Paul
'92 Coupe, Amazon Green, LSD, 17" C2's
'90 S2 Cabrio, Triple Blk
Last Post by timo944
07-05-2023, 01:55 PM
03-17-2023, 08:06 PM
Last Post by snova
01-20-2021, 03:43 AM
Last Post by snova
06-27-2020, 07:35 PM
Last Post by tejon007
07-15-2017, 10:53 PM
