Balanced/Blueprinted 968 engine
For Sale-
Sleeved block, con rods/pistons, drilled crankshaft, camshafts, new head-all recently prepped and ready for botling together. Was to be a backup engine for the #69 car. Going to Grand Am Cup-will run the 968 on a limited basis only-making the spare motor redundant. 10k and the package is yours.
Gary
[quote name='BruceWard' date='Nov 27 2005, 01:36 PM']Gary,
Has this engine been on a dyno?  What were the numbers like?
Sorry to hear you are moving away from racing #69.
[right][post="12849"]<{POST_SNAPBACK}>[/post][/right][/quote]
The original,70k engine made 205 bhp on the dyno and 195 ft-lbs torque with a race exhaust and modified air intake. Once balanced and blueprinted, the same engine makes 225-230 bhp and 217-220 ft-lbs at the rear wheels. We are using stock cams and cylinder head-without benefit of porting nor polishing-not legal in PCA stock classes-which, if done, would make more power. Most stock 968 engines have compression ratios less than the 11 to 1 specification. With the engine, 11 to 1 is assured and more power/torque is the result. The sleeving process is done for durability. BTW, we lost an exhaust valve recently-original part with 80k miles-due to simple fatigue, and inspection of the cylinders reveals exceptional results-they simply look new! This is after 15+ race weekends!
The parts are immediately available and ready to assemble. If you need more info-send me a personal e-mail.
Gary
Would someone explain, in detail if possible, what blueprinting and balancing a 968 engine means?
Trying to learn...
TIA.
balancing an engine entails carefully weighing each component of the reciprocating mass and then adjusting the weights of each item so as to insure equality of them - it generally means shaving some material off or driling some holes to remove material - this process makes for a more free revving engine, and generally increases the capacity for sustained higher revs
blueprinting is essentially a process of hand assembling, fitting, and checking each and every component, insuring perfect fit, alignment, straightness, specification, and tolerance of each of the components so they have maximum possible match to insure optimum power and longevity
it is a very time consuming and tedious process, abnd one that does not come cheaply, but one that results in a much better and stronger running engine - this is not something done by the manufacturer, at least not to the level that a race engine would be - the manufacturer has much looser tolerances and restrictions, creating a nominal acceptable condition that they can easily repeat in quantity - this process goes much farther in achieving maximum power
that is why different stock engines output different levels of power - one may do 220hp, and another 240hp, purely as a result of this process and how close the component matching and assembly was to the optimum
i highly recommend this process to anybody contemplating building an engine
[quote name='flash' date='Nov 28 2005, 11:38 AM']balancing an engine entails carefully weighing each component of the reciprocating mass and then adjusting the weights of each item so as to insure equality of them - it generally means shaving some material off or driling some holes to remove material - this process makes for a more free revving engine, and generally increases the capacity for sustained higher revs
[right][post="12879"]<{POST_SNAPBACK}>[/post][/right][/quote]
Agree with all of the above! In point of fact, the B/B of the engine resulted in (almost) negating the frictional losses from the powertrain-the engine's rated horsepower at the flywheel is 236. The same engine builder replicated the same bhp and torque numbers on Donna Amico's yellow 968 racer as with the #69 car-as both vehicles have similarly prepped engines. There's not much else to do-and stay within the PCA rules-to the motor to garner much more power.
Gary
we all want this! how 'bout a group buy? <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
seriously though - out of curiosity - what's the weight difference between parts that's allowed? or does the tolerance vary with different components? and if so... is there a written spec somewhere or do we chalk all this up to the engine-builder's art?
Gary:
You're (engine) donations would be greatly aprreciated
Ha Ha <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Last Post by SILVY968
12-02-2006, 02:34 AM
Last Post by Charles Geer
04-05-2006, 01:23 PM
Last Post by Jasen
12-12-2005, 11:34 PM
Last Post by evil 968T
11-18-2005, 08:08 PM
