I'm in the process of trying to fix my display so am making up a test jig ..... the link above is fine for extraction/insertion of the screen but not for electrical testing ....
The pin-out for our 968s measured at the socket is:
1 - 12v direct from the battery
2 - GND
3 - blank
4 - Outside temp sender
5 - 12v via F36 15Amp .... so if yours isn't working make sure you check this both at the fuse and at the socket pin.
6 - Outside temp sender
7 - 12v via instrument lights .... again, check this at the socket pin.
Does anyone know the value of the outside temp sender variable resistor???? ..... at the socket I measured 4kOhm at about 20C
TIA
