Threads: 17
Had the problem with de door trigger right as well , took it appart , was a worn thru little stud , took the handle out , took the worn stud out , used a slightly bigger drill-bit to get everything drilled out and straight again , then used the same drill , the end part wich was in the drill , and made it to length needed , hit one end with a hamer , (it is just tiny stud ) , so it was slightly out of round (just at one end so it will stay in place ) , an tapped it in to place , lubricated is with grapphite and works fine ever since .
It is actuallu a hollow tiny stud wicht holds the trigger in place , and since the lubricant if there was any , it just wears thru in time .
So it can be fixed , by yourself or a handyman
volvo V70D5 Black
Porsche 968 amethyst
Threads: 65
Necessity is, indeed, the mother of invention! Looking forward to your results report. My passenger handle is very difficult to pull, feels like it could easily break. Is there anything I can do to make it easier to open before it breaks?
Bill
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
Threads: 17
Good work !
I believe it is the worn little post it rotates around , and no lubricant , is the cause , does not explain the broken handle a 100% , maybe it had a casting fault , not as strong as it should have been .
volvo V70D5 Black
