Threads: 77
I just went with ES-12A in my newly aquired car. It is CFC based, but has a higher ignition point the R134a, so it catching fire shouldn't be a concern. This product is also environmentally friendly the EPA deemed it as not needing to be regulated and Greenpeace is endorsing it. They even put in a pine scent to detect leaks to go along withere enviromental theme. The stuff is suppose to cool better then R12 and R134A and cause less of a load on the compressor. People are actually swapping R134a for this stuff. Another nice point to this stuff is the molecules are larger then R12 or R134a so it's less likely to leak. I'm actually thinking of swapping it in my 968 which has R134a, in hopes it actually does reduce the load on the compressor. I also learned from researching R12 substitutes that one of the long term health issues with R134A is Testicular Cancer, I sure hope it hasn't been leaking into the cabin..
Tech Details here.
http://autorefrigerants.com/Envirotechnical.htm
I got mine from here,
http://autorefrigerants.com/co00033.htm
The Manufacturer is here,
http://www.es-refrigerants.com/
(This post was last modified: 07-18-2008, 06:08 PM by
banditsc.)
Threads: 77
Correct, the Envrio gas I posted above is compatible with both systems.
The main differences with the two system are the oil and the hoses. The oil that R12 uses is not compatible with R134A, so you really need to pull a full vac on the system and replace with the proper oil. Failure to do this will result in the compressor eventually failing, you also can not mix the oils. The other issue are the rubber hoses, the R134A system uses barrier hoses, putting R134A into non barrier hoses will eventually cause the gas to leak out thru the hoses. The o-rings should be compatible with the R134A, but given the age and heat in the engine bay they are most likely getting old and hard, so replacing them would assure a good sealed system.
So yes, a R134A kit will work and blow cold air in a R12 system (though not as cold), but will eventually leak out and can cause compressor failure if you don't change the oil. Or the other solution is ES-12A gas which is compatible with both systems, hoses and oils and blows as cold or possibly colder. It's price is also on par for R134A kits.
Of course if your doing any of this changing out the drier should be done if your making a change or the system has gone dry. Also if the system has gone dry pulling a vac on the system is recommended.
