Threads: 19
About 11 years ago I had a late 85 944 which I purchased with a bad A/C system in it. I thought the guy was nuts to sell the car so cheap ($7K) <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" /> but once I saw just how bad the A/C was going to be, I see he cut me a deal. <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
I had tried going to a different compressor (Rotary) originally to save $ and had to cut the ends off the original lines to install adapters for the new compressor. Mistake!!! <img src="/forum/images/smilies/968/mad.gif" class="smilie" alt="" /> The compressor was garbage and the system never ran well.
I put the old compressor back on after rebuilding it , spliced the compressor connections back on to the lines but had too many leaks. As an old aircraft mechanic I can say they weren't from my splices but rather from 4 or 5 O rings throughout the system, as well as behind the clutch at the compressor split line. As a result of all the wasted time and money not to mention really wanting a system FREE of problems, I did a complete rebuild of the system.
I worked with with Wayne (Svc Mngr) at Jim Ellis Porsche (yes he is still there) 10 Years back and I installed a retrofit kit from Porsche. I had to change out the hoses, compressor, Expansion Valve, Receiver drier, Compressor and flush everything out. The new lines had the High/Low connections in the same place as the R-12 and we installed the R134A adapters and the two new decals in the engine bay. The system worked extremely well and I did all work except for the flush, evac and actual charge of R-134a.
FYI - Porsche says you need to pull the center console/dash to replace the Expansion valve and will charge you two days labor. I went in through the engine compartment, pulled the blower motor/fan assembly and whala...there it is, straight down. I hope this info will help someone.
Stephen
Stephen
Black '95 968 Cab
Previously: '79 924, '84 944, '85.5 944, '94 968
