08-29-2009, 10:44 PM
Several of you have asked for some insight into my building the 968 turbo RSR. I'll add some photos once I figure out a place to store them.
A few years ago I put my track time on hold. I had been racing a 951 S, going to 5-6 events a year. The car was tired, and I had two in college at the same time. And then a wedding. And then another wedding. Long and short of it was, there was not cash to keep the car in good form. So, I embarked on upgrades and rebuilds. Until an eBay ad showed two 968 chassis, one a turbo S and one a turbo RS. Seems the cars had been Freisinger's and they found their way into the states. The RS of course had a cage, but it wasn't the newer cage on the red or the white car. And I had some cagey ideas of my own. So, I watched the S closely, and bid to win. I brought it home about eight years ago.
I started by taking lots of pictures. And got lots more from the fellow who bought the RS chassis, as well as Bruce Corwin when he owned the white car. Searched for factory solutions to roll cages in coupes, and made my plans.
I cut out the rear deck, fueling hose covers and the spare tire well. I removed the coil and power steering pump brackets. And the parking brake stuff. And the hood release brackets. The car already came without a lot of undercoating, and a sunroof delete roof. I bought some steel and borrowed an hydraulic bender. Made mockups and patterns, and (a large pile of misbent tubing later) managed to create a cage that looks a lot like the modifed Matter cage you see in RS's 1 & 4, with the braces to the front strut towers and to the rear shock upper mounts. I seam welded, well, nearly everywhere. I built brackets for a dry sump tank in the passenger foot well, and isolated it from the rest of the cockpit. I put in a mount for a fuel cell.
In the 951, rear tire width was always an issue, particularly when the car was lowered and given negative camber, because the tires always rubbed on the inside of the rear wells. I sacrificed the 951 to see how the rear elements were put together, then modified the 968 to accept Kevlar tubs. I added flares like you've seen on the yellow car Kelly-Moss participated in, and, well, can you say 335's in the rear? They're a snug fit, and the final rubber is still quite a ways off, but I now have that flexibility.
The factory RS's have air jacks, so I added the tubes to mount them. Only the factory gave three and I couldn't put the rear one in because I wanted the fuel cell to be a little further back. So I put in four, at the corners of the floor.
In the 951 I successfully used the front "frame" elements as a channel for air to the brakes. Always liked the carbon fiber ductwork you see on 996 and 997 race cars, but that sort of one off work can break the bank! So I inlet a 4" tube ahead of the wheel well, and inside the well forward of the strut. 4" ducting is much more flexible and doesn't kink as much as 3", so I could deliver more air to the front brakes. I used an aluminum "plate" to deliver the air into the center of the rotors, although for the new car I may make this out of stainless.
And then I moved from Florida to Alabama. The project stopped for a couple of years for various reasons. Over the past two years I worked to complete the welding--mounts for this and that, trying to look ahead so I wouldn't get a finish on the car and then sand it off to mount something I forgot. Probably a good thing to have a pause, because some safety features get better (I added mounts for a right sided net).
Finally this year I made arrangements to dip the car--to remove the factory primer and undercoating, as well as clean up some light rust that had appeared in places. I've posted on other forums about my experience, but the short version is NEVER take your car to Wauchula, FL and I'd highly recommend the shop in Allentown, PA. After stripping, it's been well washed, phosphated, and now is powdercoated.
The car, bumper covers, doors, hood, etc, are all at the paint shop now so the outside can all have the same finish.
When it returns to me, I can finally start assembly. My wife says my shop looks like an auto parts place!
Well, that's a start of the tale. More to follow . . .
![[Image: Cage%20042%20(Small).jpg]](http://dl.getdropbox.com/u/1389445/Cage%20042%20(Small).jpg)
![[Image: Oil%20tank%20mount%201%20(Small).jpg]](http://dl.getdropbox.com/u/1389445/Oil%20tank%20mount%201%20(Small).jpg)
![[Image: Cage%20top%20weld%201%20(Small).jpg]](http://dl.getdropbox.com/u/1389445/Cage%20top%20weld%201%20(Small).jpg)
![[Image: Cage%20top%20weld%204%20(Small).jpg]](http://dl.getdropbox.com/u/1389445/Cage%20top%20weld%204%20(Small).jpg)
![[Image: Car%20and%20Cage%20006%20(Small).jpg]](http://dl.getdropbox.com/u/1389445/Car%20and%20Cage%20006%20(Small).jpg)
![[Image: Car%20and%20Cage%20005%20(Small).jpg]](http://dl.getdropbox.com/u/1389445/Car%20and%20Cage%20005%20(Small).jpg)
![[Image: Car%20and%20Cage%20004%20(Small).jpg]](http://dl.getdropbox.com/u/1389445/Car%20and%20Cage%20004%20(Small).jpg)
