3rd Time a Charm?
not sure why the software is doing that, or if in fact it is - it doesn't do that to the ones i posted - if you save the file, it goes back the other way - i'll look into that when i get back - very odd
I just got home from my work place. Everything is ready to crank the engine. Spark plugs are out and coil wire is disconnected from distributor. I want to spin it a few times before lighting the fire. However, after sitting for so long the battery is quite flat. It turned on the lights on the dashboard but wouldn't even make the solenoid click. It's on a charger for overnight. We'll see what happens tomorrow. Gotta keep those fingers crossed!!!!!!!!
We're all pulling for you. Good luck!
I'm pretty sure I connected the starter wrong so I haven't been able to crank it. I've blown off this week at AirVenture in Oshkosh, WI. Ill be trying again next week.
I'm sure the collective 968 forums community has their fingers crossed for you. I know I do!
Last Post by paulzebo
07-23-2018, 10:21 PM
Last Post by BeBe
07-28-2017, 01:46 PM
Last Post by AJG
07-15-2012, 06:15 PM
