Threads: 8
My symptoms in my '88 NA 944 were on the magnetic oil drain plug. I grouping of very skinny metal shavings about 1/8" or so long, forming a little X-Mas tree shape on the drain plug.
I saw these twice in that car. Both times, #2 bearing was visibly worn. Modified the pan and pick-up during the second rod bearing change. I never had a knock.
HWFM Chief Marriage Counselor
Threads: 8
Consensus I have heard is that 968's are less prone to the #2 rod bearing problem. That said, I've seen a nice '95 M030 spin one big at the track and grenade pretty good.
I would consider rod bearings to be a PM item on any 968 north of 120k miles. For a track car/race car... PM regardless of mileage.
I did mine when I bought the car (leaking oil pan gasket anyway) and will likely check/replace them at about 50 hours of track time going forward.
Threads: 14
[quote name='Lemming' date='May 7 2006, 12:41 PM']Now the bad news - I think I know what was making the noise. After pulling the pan I remembered that I need to remove the spark plugs in order to easily rotate the crank. GUESS WHAT, #2 spark plug was loose <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> I'm thinking that was my problem all along and would explain why the spark plug cap was thumping in the first place. Don't I feel like an idiot <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
Live and learn <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
[right][post="20593"]<{POST_SNAPBACK}>[/post][/right][/quote]
We've all done something like that, some of us more times than we care to keep track of. Hey, we're only human.
I admire your aggression at getting in there to fix it, I'm still putting off an intake manifold gasket replacement project on my 911 that I should have done last year!
Bill W.
'93 968 6 spd. coupe; '97 993 Cab
'91 BMW R100GS/PD
