Threads: 45
I had exactly the same, I fitted them 5 years ago, the near side now flexes badly at full extension and causes the MoT tester a fit every year
I have a ready done set of Bilstien B6 to fit, I would suggest you look into doing either Koni or B6, the other options lower the car by at least 20-30mm
Threads: 45
The stickers are still on mine
September 2011, the core of the strut on the B6 is almost twice as thick as the Sachs
(This post was last modified: 11-24-2022, 03:05 PM by
Waylander.)
Threads: 45
I would say that they are not so much stiffer, but far better damping control, that feels like they are stiffer but the handling is greatly improved
Avoid changing for polybushes they are much stiffer, transfer more noise,
I have driven 968 with both b6 and Koni and there is very little difference, when none of these cars drive the same anyway
(This post was last modified: 11-25-2022, 05:51 AM by
Waylander.)
Threads: 49
Quote:I would say that they are not so much stiffer, but far better damping control, that feels like they are stiffer but the handling is greatly improved
On the softest setting the Konis feel pretty much like new stock ones. I prefer the Konis, and the cutting of the strut tubes was very simple and straightforward. Installing the new boots and bumpers also made a difference at full compression.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 45
The ass sagging is usually the four rubber mounts on the rear beam, they get very tired after 30 years and allow the axle to rotate slightly, all coil overs will do is make it harder at the rear as more spring is needed to lift the car back up,
New bushes and some B6 on the rear plus new ARB bushes sorted the back out with no indexing of torsion bars,
the top mounts are back in stock in Germany at nearly $500 each,
My B6 fronts are now waiting for me to get my ass in gear and fit them
(This post was last modified: 12-06-2022, 11:53 AM by
Waylander.)
Threads: 49
Martin, can you show us the rubber mounts that you are talking about, and give us some idea as to the difficulty in changing them?
Thanks,
Matt
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
(This post was last modified: 12-06-2022, 07:11 PM by
MCL968.)
Threads: 45
Ok so here we go about rear mounts
https://images.app.goo.gl/3WgukJmdETtNzLc96
So if you look at items 6 and 12
More 6 than 12, these parts delaminate and allow the rear beam to rotate a few degrees, this is enough to get the rear drooping badly, the suspension was designed to hold the door shuts level to the floor with a full tank of fuel, so about 170lbs in the boot
After replacing my 4 mounts the car looks high when empty which is most of the time, but level with my brother in the boot, I wont be able to do that again as he sadly passed away yesterday 12-12-2022
Those 4 mounts are close to $1000 but really easy to replace
(This post was last modified: 12-13-2022, 04:02 PM by
Waylander.)
Threads: 167
Very sorry for your loss
Threads: 45
Thanks guys, been a really bad year for loosing family
Threads: 65
Condolences on your loss. Life passages are never easy. I lost my brother in 2007 … still miss him.
Bill
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
Threads: 45
Part Numbers
Item 6
951.333.088.32 x2 @ $239.00 each
Item 12
944.331.075.01 Left Hand @ $236.00
944.331.076.01 Right Hand @ $236.00
