02-19-2006, 01:41 AM
In the last week I too fell victim to the dreaded 16 volt gauge reading. I've seen a thread or 2 on this topic and this idea may solve more than one issue. Like many, my first instinct was to rap on the dash and cluster to no avail. Being the curious person that I am I decided to disect the gauge cluster.
First to narrow down the possibilities I checked the voltage at the battery with the engine running and all was fine. I loaded up the alternator, again all was fine - this pointed to the gauge.
See this past thread for Dave's cluster removal detail:
16V Thread [3/05]
Note: The cluster can be removed w/o removal of the steering wheel, but it's not easy. If the designer moved connector "C" up just .25" it would make life much easier, [it'll make sense when you see the pic..].
Note: Use extreme caution when disconnecting the 3 connectors the locks are fragile! They are un-locked by moving the lever up slightly, [~.008"] and then moving it away from the center. The levers should move easily, avoid forcing them! Also, I found it easiest to remove the connectors on the rightside first, [C & B] and then A [left side]. I'm convinced they must have had some guy with small hands at the factory...
![[Image: v_g07b.jpg]](http://i26.photobucket.com/albums/c144/P968/v_g07b.jpg)
Anyway once I had the the cluster out, I applied 12v to the gauge via C5 & C8 using a power supply. Note: One side of each light is common to C8, I used the Tip contact, [see pic]. I noticed that as I ramped up past 7.0v the gauge shot up to 16v. I touched and wiggled the components and sure enough when I touched the calibration sweep-pot the voltage dropped. I attempted to adjust the pot and would end up coming back to where the factory had set it.
The problem with this type of variable resistor is after many years of vibration the contact point wears out. There's 2 ways to fix a v/r, 1) replace it or 2) add a resistor to mechanically move the set point, but electrically it would be the same. Since I had some resistors, I opted for #2. Using a decade box, DMM and power supply I found a resistance that worked. With the additional resistance in parallel to the [220 Ω] v/r, I found that ~200 Ω [+/- 30 ohms] resistance would work. I carefully soldered the resistor in place, [don't try this after caffeine - there's very little room]. I then hook-up the power and re-calibrated the gauge using 2-point calibration.
![[Image: v_g01.jpg]](http://i26.photobucket.com/albums/c144/P968/v_g01.jpg)
![[Image: v_g10.jpg]](http://i26.photobucket.com/albums/c144/P968/v_g10.jpg)
![[Image: v_g06b.jpg]](http://i26.photobucket.com/albums/c144/P968/v_g06b.jpg)
![[Image: v_g09b.jpg]](http://i26.photobucket.com/albums/c144/P968/v_g09b.jpg)
![[Image: v_g03b.jpg]](http://i26.photobucket.com/albums/c144/P968/v_g03b.jpg)
![[Image: v_g05b.jpg]](http://i26.photobucket.com/albums/c144/P968/v_g05b.jpg)
While I had the cluster out I checked all lamps - they'd be a bear to get to with the cluster installed. To get the cluster back in I had to slightly splay the dash just enough to clear the connector along the bottom. Once it was in I reversed the disassembly process.
I hope this saves some folks from buying a new v. gauge, voltage reg. and/or alternator.... <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
16V Thread [3/05]
(This post was last modified: 02-21-2006, 06:08 PM by S_Cal968.)
