good news! Since you are working on the electricals, you can do a few simple things to limit the gremlins
http://www.968forums.com/index.php?act=ST&...&st=0#entry6050 when I replaced the main fuse box. It's a good idea to pull out each fuse and replace - one at a time - same with relays. Some of these have been in place for 10+ years and the contacts get a little corroded or need reseating in the panel to restore good contact. An easy task.
Another is to recheck the grounding points in the car - will definitely help to restore panel lights, intermittent electrical device operation etc.
http://www.968forums.com/index.php?showtopic=955&st=0
Have fun with your car - the DIY things are just one aspect of ownership that makes a 968 a satidfying ride. You do learn how these cars tick.
