Winter storage
Could be a stuck DME relay. While you wait for your new one try shorting the DME pins (sorry don't have the shortcut to the diagram but it's easy to find here) and see if the fuel pump runs. Better yet tap the relay with the end of a screwdriver and try starting the car.
Thanks DaveN & Flash - will attempt tonight.
Well - I replaced the DME relay with a new one. Removed plugs & wires - tried turning over -- heard fuel pump loud & clear. Installed new plugs. And checked distro-cap. Battery cranks the starter, I smell gasoline now but she still won't start at all. I'm having car towed to local mechanic tomorrow. Where's the tow points on these? Don't see anything in the owners manual.
front uses a tow hook provided in your tool kit - there is a round cap that pops out of the upper front grill and the hook threads into that spot
there is no rear point on most cars
I checked the tool kit , the glove box, and @ the spare for the hook. It apparently didn't come with this car. Ordered one. Of course the car is parked in the garage frontend first. Nothing is ever easy.... Gotta get one of theose "Easy" buttons. Thanks yet again Flash.
05-28-2022, 02:44 PM
10-08-2014, 01:43 PM
Last Post by Jamie '92 968
11-23-2011, 04:49 PM
