11-06-2013, 11:49 PM
I installed my control arm to body bushings tonight and the new power steering rack bushings....both were worn.
One thing that I found when I brought the car in for an alignment a few weeks ago was that there was wheel bearing clearance. Most likely excessive. I went to adjust it tonight and it seems that it is adjusted correctly, but I don't know what it should feel like.
This is what I have:
If you go to Clark's Garage it states:
I can't say that I could get the thrust washer to move, does it have an indent on it that splines to the shaft?
The bearing does not seem loose to me, and I remember reading somewhere when I did my Alfa Romeo bearings earlier this year that they should have a very small amount of play when cold so they can expand when hot.
Anybody have any experiences that they can share? I can say that the steering rack rubber bushings were VERY worn (at least on the driver's side) and I remember feeling A LOT more bearing clearance before I changed them. Like a crazy amount on the driver's side. I wonder if the loose bushing contributed to that.
Thanks!
- With the wheel on and the car jacked up, if I grab the top of the tire at 12 o'clock and rock it back and forth, I would say I have about 1/64" - 1/32" of play in the bearing. I can feel it basically rocking on the inner thrust face then to the outer thrust face of the bearing. It is ever so slightly loose. No more play than slight movement between thrust faces when thrusting in or out (insert inkedupfatboy joke here).
- If I spin the wheel, it stops pretty quickly, like 1/4 to 1/2 turn max....so it's not super loose.
- If I take the wheel off, I cannot get any noticeable play in the hub by moving the brake rotor.
- After the grease cap is removed, use the medium flat tip screwdriver to turn the bearing thrust washer (just behind the locking collar). When you try to turn the washer ensure that the screwdriver is not resting on the locking collar or on the hub. If the washer spins freely or if you are unable to turn the washer using the screwdriver, the wheel bearing needs to be adjusted.
- If adjustment is required, loosen the locking collar Allen head bolt using a 6 mm Allen head wrench or long Allen head socket. To get the wrench into the head you'll have to turn the hub until the detent in the lip of the hub lines up with the head of Allen bolt.
- Once the Allen head bolt is loosened, turn the locking collar as necessary to achieve proper adjustment on the bearing (as described in the previous steps). If the washer turns too freely, turn the locking collar in the clockwise direction to tighten the bearing. If the washer is too tight, turn the collar in the counter-clockwise direction to loosen the bearing.
Thanks!
93 968 Coupe Six Speed
73 Alfa Romeo Spider
07 Audi S8
