What offser for 18"s
I have the standard replacement KYB gas shocks in the rear, with Koni yellows in front. That's been fine for a couple of DE events that I do. I just upgraded the sway bars to the M030 bars, and the castor blocks to 944 turbo units. I'll be on the track again in two weeks, so I'll really find out what difference these items have made. The car is still quite comfortable as a daily driver street car.
Checking out paragon products, looks like regular shocks aren't nearly as expensive as I thought they'd be (more worried about labour now): Shocks from paragon
. I know that regular OM shocks will do the trick, but is there something better that won't cost an arm and a leg? Or is it You-Get-What-You-Pay-For type of thing? And by better I mean stiffer for track, but still soft for daily driving.
Maybe go with standard shocks and add a sway bar instead?
-ren
-Ren
Sort of related to the topic, here are my new 18" wheels and tires.
Anchorman-
Did you use the spacers on the rear?
Bart
'92 968 Arrest me red Coupe
'71 G-Production 510 #61
No spacers on either end. I'm tempted to think about a small spacer on the rear to bring the edge out just a little more, but I probably won't bother. The offsets are 57 in front and 58 in the rear.
