12-27-2010, 08:50 AM
Trying to figure out how much weight I can loose in order to reduce optimal power requirements for a 944/968 hybrid (S2 with 968 engine)which has been a slow project for a couple of years. PCA has 2 suitable classes, one which would be perfect with the stock engine for the car (this would be the wise choice ofcourse) and one which will require a bit more than 300 hp from the engine. The first class allowes 5 kg/hp using end of race weight including driver. 50 kgs is added to rated weight for cars without ABS. Power is calculated with a 12 % powerloss. I would think it is more like 20% on our cars loosely based on 265 engine HP on rolling road with RS Barn cams and a ported cylinder head after mapping of my own car. Using a Driftbox (which is used for rating in PCS) I got 211 RWD where power is calculated from accelleration with a a total car weight given ti the driftbox.
If all this is correct I need to put the car on a serious diet. It is now 1040 kgs with carbon seats and not much in it, or 2290 lb. Interior is stripped out and the front is glass fibre with motorcycle headlights. The engine will be balanced and balance shafts removed which gives me the following list of preliminary possible savings:
Weight today 1040 kg 2291 lb
Balance shafts -9
Battery -10
Passenger seat -4
Flywheel -22,7
Wiring loom -2
Dashboard -10
Heater package -10
Charcoal canister -2 ?
Rear fenders -5 ?
Spare tire well -2 ?
Carbon luggade floor -1 ?
Empty weight 962,3
ABS allowance 50
Driver 100
Gas at end of race 10
Rated weight 1122,3
Class 8 c
HP allowed (rated) 280,575
RW Hp allowed 246,906
Real engine HP 308,6325
Any further ideas of savings or more accurate weight for the heater package and dashboard. Tried to search the forum for numbers but did not find it. Think flash has given me a heater package and dashboard weight somewhere.
And where do I find more news about the RS Barn 300 hp engine?
All the best and a happy 2011!
Torbjörn
Balance shafts -9
Battery -10
Passenger seat -4
Flywheel -22,7
Wiring loom -2
Dashboard -10
Heater package -10
Rear fenders -5 ?
Empty weight 962,3
ABS allowance 50
Driver 100
Rated weight 1122,3
Class 8 c
Torbjörn
(This post was last modified: 12-27-2010, 08:52 AM by Torbjorn968.)
