Threads: 42
I use swepco 201.
I use Bosch plugs and Bosch fuel filter.
2005 Acura RL
2004 Toyota Sequoia
Threads: 49
This is a great idea, I would love a copy when it's finished
I switched my trans oil to Amsoil because they 1) have a 75-90, which is specified and other providers had somewhat different weights, and 2) there were some negative comments about Swepco's additives and possible synchro damage.
I think a list of part numbers would also be a great idea since I find different numbers for the belts and I want to run what works best. I noted yesterday that Dayton has a regular and a heavy duty timing belt, which I had never noticed before, and I was curious as to the benefit of the HD belt, which incidentally cost around 100 more than the standard duty unit.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
(This post was last modified: 12-14-2013, 01:29 PM by
MCL968.)
Threads: 51
Affirmative on the Canton filter and cartridges. I will say it has torn apart the filter element when opened. Canton has a 2.0 upgrade that addresses this I believe.
Threads: 51
Flash what's happened almost every time I open the Canton is - yes - the top twists off - but sometimes the top doesn't let got of the perforated metal filter element before twisting it all to hell. Ha - In spite of this I still like the Canton for these cars.
Threads: 51
Threads: 77
The new ones use four bolts to secure the cap to the filter.
Threads: 51
OK! OK! Clearly user error! <img src="/forum/images/smilies/968/rock.gif" class="smilie" alt="" /> I should not be so cheap and get the upgrade.
But apologies to PeterB - let's keep this on-topic: anything else for the recommended maintenance sheet? BELTS of course should go on there, with recommended source and mfr (Gates, if you read this forum...)
