Threads: 177
Both of these seem to have occurred.
1. The A/C doesn't work. Curiously, when it is really hot, it hasn't worked before but I have always though that the switch fails in the heat because early morning or any time when it is not really hot from sitting in the sun it will work. Just a nuisance. Always worked eventually and so if I just left it on it worked pretty good with good cold air. Now it just doesn't work anytime. What is odd is that when I switch the A/C on (the voltmeter goes down indicating power is going somewhere) the amount of fresh air coming through the ducts is significantly reduced. When the A/C works this does not happen. Please note that I have not had anything checked out, just wondering if this might be symptomatic of something other than no freon. The entire climate control section was refurbished this spring and, other than this A/C problem, it works fine.
2. The car has started to idle funny and stall. Just lift your foot off the gas and, sometimes, it stalls. Doesn't stumble first, just stall as if I turned off the ignition. Starts right up again and performance does not seem to be affected. Also, sometimes idles a bit fast for no particular reason. Again, goes back to normal right away and doesn't do it often. Could this be a failing DME relay?
Kim Strong, Nova Scotia
2022 Mustang Mach-E
Threads: 137
1. low freon
2. check the easy stuff first in this order - sounds ignition related:
replace plugs
replace distributor cap and rotor
replace plug wires
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 25
Kim, just a thought but what about the DME relay?
Cloud, next time you look for sparks at the wires, mist some water on them and watch the show <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> (brings out even moderately bad wires)
Rick
Threads: 177
It was the idle stablisation valve. I had it cleaned and it seemed to make a big difference. It was completely stuck and the internals wouldn't move. BTW, the check engine code was 1-2-2-1, imtermittent problem with AFS. Light came on every time the car's idle fell too low.
Thanks folks.
PS - A/C works OK now as well (???).
2022 Mustang Mach-E
