Torque setting on the 18" wheels
I would like change these tires out and get the right torque setting on them. However I cant find the setting. Can some one help with this?
<!--quoteo(post=75401:date=Jul 12 2009, 12:17 PM:name=rhudeboye)-->QUOTE (rhudeboye @ Jul 12 2009, 12:17 PM) <{POST_SNAPBACK}><!--quotec-->I would like change these tires out and get the right torque setting on them. However I cant find the setting. Can some one help with this?<!--QuoteEnd--><!--QuoteEEnd-->
i believe that it is 96.
brian
Yes, that's right. Although Flash made an interesting point that if you use anti-seize (which I always do), you need to apply slighty more torque than if you don't, though he wasn't sure how much. Maybe a nice round 100 lb-ft would be in order if you use grease on your lug studs.
Thanks to both of you. I was borrowing a friends wrench so I needed the answer fast. Within 5 minutes Brian came through.
Thanks B
My 18" twist are now on and properly torqued. They look amazing!
03-19-2009, 10:42 PM
