Time on your hands?
If you have a few minutes to spare, I need for someone to measure the distance from the tread center line of the left rear tire to the tread centerline off the right rear tire. The tech data says that this should be 57.1 inches in he OEM condion. If your tire sizes are not stock, your results may vary a little. Before I start cutting slots in my trailer floor, I would really like to verify the number. I figure asking you guys will be a lot quicker than driving to Tampa and breaking in at HMR to measure my ride.
TIA!
Mike O
I just measured 57 1/4 inches. I have stock 17s.
WONDERFUL! That's close enough for me to cut up the trailer without too much of a knot in my gut. I will be using a single strap over the top of the tire in the rear and a through-the-wheel strap in the front. Vertical E-track will run under each side the full lenght of the trailer. The E-track will be recessed hence the cutting up the trailer floor phobia.
Thanks for your help!
I have stock 16 inch wheels, and I measured it to be 57-3/8 inches.
OK, I cut the grooves in the trailer floor for the E-track today. Thanks to both of the guys that had "time on their hands" for the quick response measurements on Sunday. Pictues in a couple of days.
Last Post by mikeo
05-02-2005, 10:29 PM
