Thumbnail size
I've been participating in another forum which appears to use the same software as this site. The moderator has set the thumbnail size for attached images to be 2- or 3-times what we see here.
On my 1280/1024 setup the current thumbnails are just that, and very hard to make out. Larger thumbs serve as virtual proxies for the image and often mean you don't have to take the time to upload the full image into its own window to get what you need from it.
Anyone see a reason NOT to enlarge thumbnail sizes here a bit if it's possible?
I agree completely generally the lowest resolution I run is 1600x1200 and I wll go much higher depending on what machine or docking station I use.
Last Post by jakerade
03-04-2005, 04:13 AM
