Threads: 49
I have read a few old threads about jacking points, and some have stated that jacking the front of the car up using the front cross-member is preferred to using the side jacking points.
This would be preferable for me if it is, in fact, safe. Placing the jack stands under the jacking points is impossible if there is already a jack there, and jacking the car up using the jacking points and then using wheel blocks is also great, unless you are working on the brakes.
Anyone out there with experience on this subject? As it stands now (pun intended) getting the front end of the car high enough to work on using the jacking points takes a lot of time and if one uses wheel blocks one cannot remove the wheels.
Thanks!
Matt
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 77
Threads: 177
Kim Strong, Nova Scotia
2022 Mustang Mach-E
Threads: 49
Thanks Bob and Bob. The pics will be helpful, as I seriously hate getting this car off of the ground to work on it.
M-
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 77
The have different saddles for that jack stand, the pinch weld one is the one they are using for the demo, apparently on that car the manual says to use the pinch weld.
Threads: 51
That stand is nice but you could never get one under my car. I can barely get the jack alone under there much less that adapter.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 142
I've been wanting to try one of these, or I guess two are required for full car lift. It is a single bar that lifts the car from both jack points at the same time, and then the jack stands are placed under the bar at those same jack points.
http://www.liftbars.com/
Roland
Threads: 49
Quote:I've been wanting to try one of these, or I guess two are required for full car lift. It is a single bar that lifts the car from both jack points at the same time, and then the jack stands are placed under the bar at those same jack points.
I'm SOLD! We need to make these for the 968. What a great and simple idea.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 77
That would be Ken, he is big the 928 scene, I run his chips in my 928. Really nice guy, up in the Oregon area.
