Threads: 65
The “968” numbers insignia on the rear deck on my Cab has worn with a lot of white showing. I’d rather not spend $70 for a new insignia and it just seems wasteful to replace rather than refinish. I assume there is some type of paint or marker I could use to make the numbers all black again. Anyone else ever done this? Suggestions greatly appreciated.
Bill
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
Threads: 167
Hi Bill,
Not sure why this was "invisible". It seems like a perfectly legitimate question.
Threads: 9
What are the rear badges made from? When I had my Mk1 Jetta, I painted a plastic grille badge using Humbrol model kit enamel paint and it came out alright - may be worth a look?
Michael
'95 968 Sport
'73 VW GT Beetle
Threads: 45
Quote:If you care, Wurth makes a black trim paint that worked great on the black trim on my SC. Otherwise, just get some black Krylon. Remove the numbers,* sand, paint, replace.
*I used dental floss and mild heat to remove mine when I went from black to silver numerals.
I have silver numbers too, thought it looked a bit blingy, but used to them now
