04-03-2009, 09:56 AM
So, my newly accuired 968 feels weak, as in I don't think all of the 240 ponies are home at the moment. I haven't driven any other 968's so I cannot really compare but it does not pull as strong as I would suspect a CS with roughly a 150 lbs diet should. A friend of mine has tested the car and he too is thinking that it lacks power and he has driven a couple of others in various shapes.
I have not done a compression or a leak down check but the engine seems leak free and doesn't smoke, use oil or anything else that is normally associated with a worn out engine. This is despite me deliberately trying to make it do so.
I am doing the variocam check this weekend, if I can find the time, not so much due to the lack of power but to get a good nights sleep. In the nearby future the car will have all belts and variocam parts replaced (hopefully the cams are ok) and I will also see if I can get someone with the proper knowledge and tools to time the exhaust cam to make sure everything is as good as can be.
The engine pulls smooth without missing or hesitating all the way from idle to the rev limit. It does not vibrate (not more than you'd expect from a 3-litre in line four) or make any odd noise.
Could the variocam solenoid be broken/stuck, thus disabling the variocam?
The car is in an overall need of service. Could it be that it simply needs new ignition parts, the injectors cleaned and calibrated and such?
Or am I simply asking to much of a 14 years old car with a 100k on it?
Any thoughts on this would be greatly appreciated.
(This post was last modified: 04-03-2009, 09:58 AM by firefish.)
