SUNROOF TROUBLE ..... THE SWITCH ....
When I first bought my 93 968 i stripped my gears.I ordered new ones off of paragon. Until one of the arms is lower than the other. So I figured the timing was off so i cracked it open. Then the position down button for the sunroof wont work. Therefore the cable shot out into the back.Now I cant Retract the cable because the the button wont pull the cable back in. Im assuming its a bad relay or the motor is burnned.
Can anyone please help me..
Alex
Man, I'd hate to graph those sentances! <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
Im sorry im working and i typed it up real quick. Sry mates. I edited so its a little clear. So does anyone have any suggestions.
thank you
Sounds like you exceeded the limit switch travel. #1, feed the cable back into the gearbox in the headliner. You will have to get into the mechanism at the DS rear panel area - it can be done. Seldom will you have relay or electric motor failure on the roof - it's usually the gears and the limit switch issues at the root of the failure. With the drive cable pulled back so far, you will have to manually feed it forward again.
It's all relatively easy to do - but you must be patient! 2-3 hours max to re & re IIRC - check post http://www.968forums.com/index.php?showtop...563&#entry22563 or use search for more info. good luck - careful not to strip the new gears either (don't ask why I know). gears are cheap from Paragon, so get a spare or 2
read the post for reasons why the Key is to adjust the SLIP CLUTCH
Thank you ill give it a try.
11-24-2019, 03:15 PM
Last Post by Inkedupfatboy
03-18-2017, 11:36 PM
Last Post by ryker
10-09-2013, 11:15 AM
Last Post by DaveN
03-26-2012, 07:13 PM
Last Post by Cloud9...68
02-12-2012, 06:40 PM
Last Post by mdss
12-17-2011, 06:08 PM
Last Post by Mark
06-13-2011, 09:15 PM
