First, make sure you check all the fuses that pertain to the sunroof operation; I believe there are at least two. If these are all OK, I would go to
www.clarks-garage.com, which has a great step-by-step troubleshooting guide for the sunroof. It looks a little intimidating because it is so detailed, but therin lies its value as well, so just take your time and read through it. I would start with the console switch; Clark's Garage explains how to remove it, and then you can test it with an ohmeter, which I believe the site also explains how to do. I would next check the switch bewteen the sun visors. It's possible that it isn't being "made" by the little tab on the sunroof. Try pusing it by hand; if you hear a click, that's likely your problem. If these check out (hopefully it's not the console switch, because it's fairly expensive), proceed through all the other electrical components (relays and swtches) and test them all, which Clark's garage also explains how to do.
I feel your pain - the sunroof mechanism is very complicated on these cars, and a lot of work to troubleshoot. But the fact that you're not getting any response at all at least narrows it down to an electrical component of some kind.
