07-03-2008, 11:18 AM
Finally got around to looking into this.
1) Did the blink test. Oddly, using unknown's procedure I was not able to get the check engine light to ever flash with the accelerator depressed. Engine off, ignition on, fully depress - no flashing light. The light does come on when you turn the key to the second position (just before turning the engine over).
2) Did the dark garage test. Both after a 30 minute drive with the engine fully warmed and again this am when cold. Other than a little CO poisoning no issues - no sparks at idle or when advancing the throttle. I heard a nice little gulp of air when throttling up since the air box mod - but that is neither here nor there.
Having the car for a few months now and having driven it about 2KI am more familiar with the problem so I will restate here.
a) Idle is fine. Starts and runs smooth and steady at about 1K RPM.
<img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" /> Runs fine during strong acceleration through all gears
c) When running at about 2000 RPM at a light, and engaging the clutch in first, it bogs a bit, looses RPM and will stall if not revved.
d) When downshifting to second when approaching a light or stop, will do the same thing at about 2000 RPM.
e) Also, and this one is concerning, when coasting at 20 - 25 MPH, trans in 2nd, and engaging clutch, engine (I think) shudders. Does this very sporadically, but if I get the conditions right (slight downhill in neighborhood going slowly in 2nd and letting the clutch out at 20-25 MPH) I'll get the shudder - both when cold and warm.
Thoughts?
Thoughts?
