Threads: 224
Threads: 224
<!--quoteo(post=71954:date=May 14 2009, 06:45 PM:name=flash)-->QUOTE (flash @ May 14 2009, 06:45 PM)
<{POST_SNAPBACK}><!--quotec-->if you look closely, in stock form it would only do about 60 in 2nd (6700 redline)
that being said, i can do about 70 in 2nd if i tach it out, but i'm not inclined to do that<!--QuoteEnd--><!--QuoteEEnd-->
After looking back at the chart I noted that also. Without the chip my limiter will not allow me to hit 7grand. So I need to follow that line down to around 63mph.
BTW I think you might even get a little more then 70mph in 2nd. If that gear was designed to move the stock weight up to 70mph, with your mods and weight reduction, chances are youll pass it.
<!--quoteo(post=71955:date=May 14 2009, 06:51 PM:name=ds968)-->QUOTE (ds968 @ May 14 2009, 06:51 PM)
<{POST_SNAPBACK}><!--quotec-->all the way to 150 shifting into 6th. It still pulls in 6th beyond 150 but
conks out around 165 + mark..<!--QuoteEnd--><!--QuoteEEnd-->
Funny, I don't recall hearing about you entering any DEs Dan.
So can you do 70 in 2nd? And where in the RPM range do you shift?
