Steering Shafts
If you guys are interested....
now the LHD steering shaft is NLA I thought I would let you know that the joints can be replaced fairly easily
You will need a vice, some patience and a few other tools.
I have rebuilt about 20 of these now so I am practiced at it.
you will also need two Bailey Morris universal joints (BM210), might not be available in the USA but I'm sure a equivalent will be.
these little joints are staked so with a little care and a modified cold chisel they can be re-staked again.
the joints cost over here about $40.
http://baileymorris.co.uk/universal-join...t-bearings
When I was having my shocks replaced the mechanic leant on the hub nut with his extension bar. This caused the front wheel to rock backwards a degree or two, not much, but I assume not ideal either. Is this likely the bushes in the control arm, or symptomatic some other wear?
I ask because I have the opportunity to get under the car next week and have a look around. So some guidance of where to look and what to look for would be helpful.
Its not so much of an issue on LHD cars, as its not close to the exhaust
The heat on RHD cars kills the joints
Okay thanks.  Hopefully I'll be able to reproduce the symptom when the car is up, and can see what is flexing / not holding....
Another great find Waylander.
Are the steering shafts the same on the 944? I was thinking of picking up a used 944 unit and rebuilding it and just swapping it out so the car would not be out of commission for as long.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Yes they are the same
No I am 99% sure they are not!  i believe that the 944 version is a mirror image of the 968 version. I had to buy one from a dismantler and it was useless when it arrived.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
The steering shaft part number is
LHD 944.347.027.03 @ $305
This fits
[Image: LHD_Steering_Shaft.jpg]
[sharedmedia=gallery:albums:395]
I have been posting images from AWS for ages, today it will not work for some unknown reason
Last Post by BOB968
07-22-2021, 06:21 PM
