[quote name='Greimann' date='Mar 3 2006, 09:38 AM']If you are going in for a clutch job, be sure to replace the fork pivot shaft and needle bearings. The shaft gets little dents impressed in the surface, giving the pedal a notchy feeling. Much smoother with new parts.
When taking down the exhaust system, remove the whole thing in one piece from the header flange to the muffler. Much easier to remove the hanger bolts than wrestle with the top two bolts at the cat flange.
O2 sensor original? It should be replaced at least once in the cars lifetime.
[right][post="16890"]<{POST_SNAPBACK}>[/post][/right][/quote]
I have the clutch disk, PP. TOB, release lever shaft bearings, new flywheel bolts, pilot bearing and rear seal coming from Paragon, parts should be here today.
Thanks for the tip on the exhaust system. As for the O2 Sensor, I'll look through the records but I don't think it's been replaced and w/ 105K on the clock it's about due. Thanks for the reminder, I went through a faulty O2 sensor problem on the 911, don't want to do that again though now my troubleshooting skills should be much better.
I would rather just replace the brushes if I can, save $90+ for other projects.
