Threads: 69
Owning both a Cab and a Coupe and having an audio background, I can tell you that the Coupe is much louder than the cab and it is indeed from external sources. I've been driving the Coupe for a while now with no radio at all after removing all of the previous "top of the line" CASSETTE based head unit system. As Flash points out, I concur that most of the drone is from the rear tires and road noise reverberating in the "bowl".
I have finally collected all of the necessary parts and pieces to do the rear speaker enclosure mod. Since I'll be replacing the old speakers, one of which is blown anyway, with new 6.5" coaxial drivers and doing the mod at the same time, I won't really have a before and after but I know it'll be tons better. I plan to do the doors as well while adding the new 5.25 2 way component systems in each door. I opted for the B Quiet extreme since after doing the research, seemed like a very decent alternative to Dyna-Mat, and a forum member had a huge roll for sale...so I got about twice as much deadening material for about 1/2 the price I would have had to spend on the DynaM-Mat. Gotta love the forum!
Threads: 15
Definitely agree - road noise from the rear tires is often deafening, depending on the road surface. I've got some dynamat back there, and will eventually be covering just about every surface I can get to.
Recently my city has begun repaving streets using asphalt that contains ground-up recycled car tires. It's almost completely silent when you drive on it.
-Austin
'94 Black/Tan Coupe
Threads: 15
I think mine are from 2009. Probably time to start thinking about new ones.
-Austin
'94 Black/Tan Coupe
Threads: 15
I just put Sumi HTRZ 3's on the BMW. So far they're quiet and feel similar to the Michelin PS2's they replaced. Will have to try them on the 968, seeing as this car needs the quietest tires it can get. Still gonna dynamat everything in sight tho - or
out of sight I should say...
-Austin
'94 Black/Tan Coupe
(This post was last modified: 10-02-2012, 08:00 PM by
bombfactory.)
