10-03-2006, 06:57 PM
My 968 has been fairly well relegated to track / autocross duty. The only time it seems to hit the street is when I need to burn some gas, test a mod or take it to the shop. At the last two track events I've developed CV joint noise in very hard right hand turns. The noise comes from the right hand (unloaded) side of the car. At both events (two different tracks) the noise developed in the second day in the same type of corner. Before the most recent event I completely disassembled and relubricated the joints. The joints looked fine with some wear in the cages.
My mechanic (who also races in our club) believes that the transmission and rear components are moving enough to compress the axle into the transmission or hub thus causing the noise. Alternately, it could be pulling the axle and CV joint apart enough to basically hyper-extend it. Either way, he feels stongly that the noise is a symptom of the rear components moving around. I've got to find a solution to this before the next track event. Based on the noise that developed Sunday something is going to break soon.
His proposed cure for this is installing a solid transmission mount and solid bearing for the trailing arms. I've already replaced the transmisson mount with an OE one a couple years ago. Anyone experience the same thing in their track car? Anyone know where to get a solid transmission mount? I could only find one for a 951 from Kokeln and it requires a 951 cross member to fit the 968.
