02-06-2006, 03:28 PM
Man, has this board gotten quiet over the last week or so!! With Spring right around the corner, all us "cold country" folks should start thinking about the driving season!
So, I'll use the silence to start a discussion about something that has been popping up on this and the Net boards: "How high can you rev a 968?". With the redline set well below 7000, there is a lot of talk about running our cars to 7700 and beyond. To my knowledge, the only Porsche's I have seen that could run in those areas, and live, are race prepared cars.....which are set up with rev limits up around 10,000!
It would appear that the individual components (cams, valves, connecting rods, etc) are capable of the high loading that high revs produce, but I worry about things like valve float, bearing loading, cam lobe wear, etc. Without the stiffer valve springs that the race cars run........when can we expect our valves to begin to float......(i.e. not fully allow for full valve closure because the inertial forces can't move them closed fast enough because of the lighter spring rates)? And, with an interference engine, like the 968, how much valve float can be tolerated before we begin running valves into pistons?
And, what about rod bearings or the small end bearings? I know that they are all capable of withstanding higher revs.........but, for how long? Today, it is not unusual to see engines that make 150K+ miles without a rebuild. If the engines are repeatedly subjected to the red line plus region, will these become 80K mile enignes.....or less? I know that in a competitive race car, getting two or three runs out of an engine is about all you can hope for to stay competitive........so, what are we doing to our cars at higher revs? Conversely, if they are capable of the higher rotational speeds, why has Porsche set the rev limiters in the low 6K area?
Having owned a few P-cars, I personally have always felt that they run better if you run them hard.......but, I have always tried to pay attention to red line. And, I have consistently gotten well over 150K miles out of engines and trannies.
Most of the chips for the 968 really don't show much until you hit redline or greater engine speeds..........but, what will that do to the lives of our engines?
Your comments would be appreciated.!
Regards,
Ernie
Regards,
Ernie
